Client script is not working for specific users
04-07-2022 01:48 PM
Hi Team,
i have created customer changes record producer for change req mgmnt
i have created a catalog client script to load put some values
i have written alert to check that script is reachable or not
i found issue with some users and a pattern
if i create a user in sys_user table and assign company and " itil "and "snc internal role" --client script is working fine
when i'm creating user from core_copmany giving same roles was not able to access client script
note: Both users are having same roles same company
it simple client script nothing complex
consider only one line of code alert("reacgeble load script");
can anyone help me overcome the issue
Change Management
04-07-2022 10:24 PM
are you sure it is able to query question_choice table?
try this
var GetCompany = Class.create();
GetCompany.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getDetails:function(){
var company = this.getParameter('Company');
var gr = new GlideRecord('question_choice');
gr.addQuery('question','a17c310087c64110fc692f49cebb351a');
while(gr.next())
if(company.indexOf(gr.text.toString()) > -1)
return gr.text;
type: 'GetCompany'
04-07-2022 10:28 PM
before calling script include it should through alert i have commented all code expect that alert then i checked but it is not reaching to client script
04-07-2022 10:38 PM
don't use includes use indexOf
function onLoad() {
//alert(g_form.getDisplayValue('company'));
var company="Visteon 1";
alert(company.indexOf('Visteon') > -1);
var ga =new GlideAjax('GetCompany');
ga.addParam('sysparm_name','getDetails');
ga.addParam('Company',g_form.getDisplayValue('company'));
ga.getXML(getResponse);
function getResponse(response)
var answer =response.responseXML.documentElement.getAttribute("answer");
alert(answer);
if(answer!= null)
g_form.clearOptions('please_select_the_customer_specific_change');
g_form.addOption('please_select_the_customer_specific_change','','-- None--');
g_form.addOption('please_select_the_customer_specific_change',answer,answer);
04-07-2022 10:48 PM
is not the above code for only specific users client script is not reachable
now i have given one line of code
alert("reaching inside");
commented everything what i have witten
but still not that users client script is not reachable
04-07-2022 10:51 PM
Sorry I didn't get you.
you are saying client script itself is not triggering when you change?
OR Ajax is not working for that user?
