Client script is not working for specific users
Sriramachandra1
Hi Team,
i have created customer changes record producer for change req mgmnt
i have created a  catalog client script to load put some values
i have written alert to check that script is reachable or not
i found issue with some users and a pattern
if i create a user in sys_user table and assign company and " itil "and "snc internal role" --client script is working fine
when i'm creating user from core_copmany giving same roles was not able to access client script
note: Both users are having same roles same company
it  simple client script nothing complex
consider   only one line of code  alert("reacgeble load script");
can anyone help me overcome the issue
@Ankur Bawiskar @Sandeep Dutta @Mark Roethof
17 REPLIES 17
it is onload catalog client script
client script is not working
and client script is not reachable for that users
your requirement is not clear.
you are sending company value to script include but not using it?
hey ankur
ignore about script include and all
i have written now onload client script
with below code
function onLoad() {
alert("checking users to can access this svcript");
and it is working for admin and type1 users mentioned in question and type2 user not able reach the alert code
is the other user having access to the form?
can you share the form screenshot?
