08-30-2021 10:07 AM
Hi Guys,
I have a Requested For variable (itsm_requested_by), a checkbox (include_me_in_the_access) and a mrvs (users_who_need_access). When I checked the checkbox it will add the Requested For to the mrvs, then when deselecting the checkbox it should be remove from the mvrs.
I came across from one of the question and was able to add the details in my mrvs by creating script include + client script (onChange)
Script Include:
var populateEmailfromList = Class.create();
populateEmailfromList .prototype = Object.extendsObject(AbstractAjaxProcessor, {
listcollector: function() {
var listValuename = [];
var userInfo = this.getParameter('sysparm_user_info');
var query = 'sys_idIN' + userInfo;
if(userInfo)
gr.addEncodedQuery(query);
if(gr.next()){
listValuename.push({
"name": gr.getUniqueValue('name'),
"ntid": gr.getValue('u_network_id')
gs.info('ARB JSON'+JSON.stringify(listValuename));
return JSON.stringify(listValuename);
type: 'populateEmailfromList '
OnChange Client Script:
if (isLoading) {
if(newValue == ''){
g_form.clearValue('users_who_need_access'); // give name of MRVS variable set here
if(oldValue != newValue){
var ga = new GlideAjax('populateEmailfromList');
ga.addParam('sysparm_name', 'listcollector');
ga.addParam('sysparm_user_info', g_form.getValue('itsm_requested_by')); // give here the requestor variable name
ga.getXML(listcolleValues);
function listcolleValues(response) {
var val = response.responseXML.documentElement.getAttribute("answer");
if (g_form.getValue('include_me_in_the_access') == 'true') {
g_form.setValue('users_who_need_access', val); // give name of MRVS variable set here
else if (g_form.getValue('include_me_in_the_access') == 'false'){
var toRemove = g_form.getDisplayValue('itsm_requested_by').value;
var finalArr = [];
var parser = JSON.parse(val);
for(var i=0;i<parser.length;i++){
var obj1 = parser[i];
var newParser = JSON.parse(JSON.stringify(obj1));
if(newParser.name != toRemove){
finalArr.push(obj1);
alert('new JSON' + JSON.stringify(finalArr));
g_form.setValue('users_who_need_access',JSON.stringify(finalArr));
Unfortunately, the "else if (g_form.getValue('include_me_in_the_access') == 'false'){" in my client script is not working for me. Please help me with my script.
Appreciate for any assistance.
thanks,
Sarah
Service Catalog
08-31-2021 07:23 AM
you need to again perform GlideAjax when it is checked so that you get the user details and add it to existing json string
08-31-2021 01:12 AM
This is the client script I have created in the checkbox.
if (g_form.getValue('include_me_in_the_access').toString() == 'true') {
} else if (g_form.getValue('include_me_in_the_access').toString() == 'false'){
var finalArr = [];
if(parser[i].name != toRemove){
finalArr.push(parser[i]);
08-31-2021 02:26 AM
name variable within MRVS is reference type or string?
if it is reference then do this
var toRemove = g_form.getValue('itsm_requested_by');
if it is string then do this for getting display value in portal
var toRemove = g_form.getDisplayValue('itsm_requested_by');
08-31-2021 02:45 AM
Hi Ankur,
itsm_requested_by is a reference field. I have changed it to
but now it removes all the details in the mrvs. Where did I do wrong here?
else if (g_form.getValue('include_me_in_the_access').toString() == 'false') {
var finalArr = [];
for (var i = 0; i < parser.length; i++) {
if (parser[i].name != toRemove) {
08-31-2021 02:50 AM
try to add alert and debug
var finalArr = [];
alert('Name is' + parser[i].name);
alert('Pushing when value is not matched');
08-31-2021 02:57 AM
