08-30-2021 10:07 AM
Hi Guys,
I have a Requested For variable (itsm_requested_by), a checkbox (include_me_in_the_access) and a mrvs (users_who_need_access). When I checked the checkbox it will add the Requested For to the mrvs, then when deselecting the checkbox it should be remove from the mvrs.
I came across from one of the question and was able to add the details in my mrvs by creating script include + client script (onChange)
Script Include:
var populateEmailfromList = Class.create();
populateEmailfromList .prototype = Object.extendsObject(AbstractAjaxProcessor, {
listcollector: function() {
var listValuename = [];
var userInfo = this.getParameter('sysparm_user_info');
var query = 'sys_idIN' + userInfo;
if(userInfo)
gr.addEncodedQuery(query);
if(gr.next()){
listValuename.push({
"name": gr.getUniqueValue('name'),
"ntid": gr.getValue('u_network_id')
gs.info('ARB JSON'+JSON.stringify(listValuename));
return JSON.stringify(listValuename);
type: 'populateEmailfromList '
OnChange Client Script:
if (isLoading) {
if(newValue == ''){
g_form.clearValue('users_who_need_access'); // give name of MRVS variable set here
if(oldValue != newValue){
var ga = new GlideAjax('populateEmailfromList');
ga.addParam('sysparm_name', 'listcollector');
ga.addParam('sysparm_user_info', g_form.getValue('itsm_requested_by')); // give here the requestor variable name
ga.getXML(listcolleValues);
function listcolleValues(response) {
var val = response.responseXML.documentElement.getAttribute("answer");
if (g_form.getValue('include_me_in_the_access') == 'true') {
g_form.setValue('users_who_need_access', val); // give name of MRVS variable set here
else if (g_form.getValue('include_me_in_the_access') == 'false'){
var toRemove = g_form.getDisplayValue('itsm_requested_by').value;
var finalArr = [];
var parser = JSON.parse(val);
for(var i=0;i<parser.length;i++){
var obj1 = parser[i];
var newParser = JSON.parse(JSON.stringify(obj1));
if(newParser.name != toRemove){
finalArr.push(obj1);
alert('new JSON' + JSON.stringify(finalArr));
g_form.setValue('users_who_need_access',JSON.stringify(finalArr));
Unfortunately, the "else if (g_form.getValue('include_me_in_the_access') == 'false'){" in my client script is not working for me. Please help me with my script.
Appreciate for any assistance.
thanks,
Sarah
Service Catalog
08-31-2021 07:23 AM
you need to again perform GlideAjax when it is checked so that you get the user details and add it to existing json string
08-31-2021 03:22 AM
did you check toRemove also has same sys_id
try this
if (parser[i].name.toString() != toRemove.toString()) {
alert('Pushing when value is not matched');
finalArr.push(parser[i]);
08-31-2021 03:34 AM
Hi Ankur,
I have tried to removed the .name, it is now looks like below, and i can now received the alert.
if (parser[i] != toRemove) {
However, when I go to the last part:
g_form.setValue('users_who_need_access', JSON.stringify(finalArr))
it retained my name and the rest of the records removed aside from my name.
08-31-2021 03:37 AM
yes. toRemove has the same sys_id with parser[i].
08-31-2021 05:47 AM
can you share what's coming in this
alert(val);
08-31-2021 07:11 AM
Hi Ankur,
I am now able to make it work. I just created one catalog client script (onChange). I removed the script include and just populate the details in the hidden variable. So the client script will looks like below.
var selfDetails = [];
var details = '';
var obj = {};
obj["name"] = g_form.getValue('itsm_requested_by');
obj["ntid"] = g_form.getValue('ntid1');
selfDetails.push(obj);
details = JSON.stringify(selfDetails);
if (newValue != '' && g_form.getValue('include_me_in_the_access').toString() == 'true') {
g_form.setValue('users_who_need_access', details);
else if (g_form.getValue('include_me_in_the_access').toString() == 'false'){
var details1 = g_form.getValue('users_who_need_access');
var toRemove = g_form.getValue('itsm_requested_by');
//alert(toRemove);
var finalArr = [];
var parser = JSON.parse(details1);
//alert('Name is ' + parser[i].name.toString());
if(newParser.name.toString() != toRemove.toString()){
//alert('Pushing when value is not matched' + parser[i].name.toString());
//alert('new JSON' + JSON.stringify(finalArr));
//g_form.clearValue('ntid1');
However, i have more issue. When I tried to select the checkbox it populates my details in the mvrs, but the rest of the initial records cleared out. Do you know how I fix this part?
