‎04-13-2022 01:17 AM
Difference between catalog builder and maintain items ?
Benefits of using CATALOG BUILDER , being a developer we should use catalog builder or maintain items ?
Where the catalog item created by using CATALOG BUILDER will be shown to users ?
‎04-13-2022 07:38 AM
Items created through catalog builder will be visible in the portal with no differences for end users. The difference is in the creation process, it is now much easier and quicker to produce a catalog item compared to the traditional way.
‎04-13-2022 02:21 AM
Catalog builder is a more intuitive and easy way of creating catalog items. It's a step by step visually appealing method to create/test a form and once it is published it will be visible to end-users. Also, there is an option to use templates to create catalog items so users don't have to spend time creating things from scratch.
‎04-13-2022 02:36 AM
Items created through builder will also be available on portal for users and with same view?
So, for end users using catalog builder wont bring any change in look or use ..right ?
