12-19-2020 07:59 AM
Hi
I am looking for the difference between getTableName() and sys_class_name
any approach with practical implementation is appreciated.
Thanks in Advance
Amey
Incident Management
12-19-2020 08:04 AM
Please reference this post which asks the same question: https://community.servicenow.com/community?id=community_question&sys_id=6a3e87eddb9cdbc01dcaf3231f96... and contains use cases, etc.
Essentially, once is utilizing a field on a table to retrieve that information whereas the other is calling a function...to then go and get it. So it's advisable to use the field versus calling a separate function to go and retrieve it if it exists (i.e. only exists on tables extended from Task).
12-19-2020 08:25 AM
Thanks.
I will be going through this in more detail.
12-19-2020 08:49 AM
Thanks Allen for correcting.
Amey refer this also
I have referred this.
If the above code helps then please mark my answer Correct and Helpful.
Thanks and Regards:
Siddhnath Pandey
