Dot walking not works for dependant fields ?
bourhoud
Kilo Expert
Hi all,
Working on a Helsinki instance.
I have an issue on dependant field, set on a choice list :
My choice list is a custom field on alm_hardware, which contains status. These status depends on the type of another OOB reference field, stockroom.
Let's be more concrete :
If I select a stockroom which has type "Central Warehouse", my list of values contains several status.
If I select another stockroom, with another type, my list of values changes for anothers status, specific for this type of stockroom.
To do this, I set the following :
- Check dependent field to be true
- dependent on field : stockroom type
- specifies a dependant value for one of my choices, with the sys_id of central warehouse type
My tests go wrong, my choice never appears, even if I select a central warehouse stock room.
If I do the same, by specifying my choice list directly dependant on a stockroom (without dot walking), it works...
Does anyone know where I'm wrong ? Is it a known issue in Service Now ?
Yes, that's how I do things when needed.
Scripting can be avoided in many cases in SNOW, but sometimes it cannot be avoided, and I think this is one of those cases.
harel
Ok, I take in account your point of view, that I share...
I'm just disappointed that using dot walking for dependant values doesn't work
Thanks harel.
harel,
Please note that I've managed to make it work, but... it needs the Asset form to be reloaded, to reload choice values list with the one I want...
I really don't understand why it works on change, in real time, when it depends on stockrooms id, but it doesn't when using dot walking...
So, I don't have other choice to implement your solution.
Thanks you again.
Can you explain what you mean by " it needs the Asset form to be reloaded, to reload choice values list with the one I want."
harel
Please mark as correct or helpful based on impact
When I just change my stock room, as explained in this topic, nothing happens, my stock status list doesn't change.
But I noticed that if I reload my form, my stock status contains values I want, for the type of the stockroom I selected =/
If I resume the issue :
stock status dependent on stock room : it works, I change my stock room and my stock status list changes in the same time.
stock status dependent on stock room type (so with dot walking) : doesn't work except if I reload the form....
Strange, isn't it ?
