Dynamic filter using script include as reference
tiagomacul
Tera Sage
I'm trying to create a Dynamic filter using script include or also Business Rules, how ever, I've been trying and when i tried to recognize how to do:
  1. Script include / Application: Global / Accessible from: All application scopes
  2. Dynamic Filter / script: javascript: new <includename>.<function name>(); / Reference Script: Script Include: <includename>
Script Include
var appLogin = Class.create();
appLogin.prototype = Object.extendsObject(AbstractAjaxProcessor, {
filterMe: function(){
var vuserid = gs.getUserID();
vReturn = "";
      vIsTrue = this.isTrue();
if (vIsTrue== false)
vReturn = vuserid;}
else
vReturn = this.GetMyBoss();
return vReturn;
isTrue: function(){
var ObjUser = new GlideRecord('sys_user');
ObjUser.get(vuserid);
var vistrue= ObjUser.u_istrue;
return vistrue;
GetMyBoss: function(){
var vmyboss= ObjUser.u_myboss;
return vmyboss;
type: 'appLogin'
Dynamic FIlter Options
  • new x_appLogin().filterMe()
    • org.mozilla.javascript.EcmaError: "x_appLogin" is not defined.     Caused by error in <refname> at line 1==>     1: javascript: new x_appLogin().filterMe();
  • new x_appLogin.filterMe();
    • org.mozilla.javascript.EcmaError: "x_appLogin" is not defined.     Caused by error in Phase 2 Jelly: file:/glide/nodes/xxxxxxxxxxxxxxxx004_16033/webapps/glide/itil/WEB-INF/ui.jtemplates/doctype/template_bar.xml.2 at line 1==>     1: new x_appLogin().filterMe();
  • new appLogin.filterMe();
    • org.mozilla.javascript.EcmaError: undefined is not a function. Caused by error in <refname> at line 1 ==> 1: javascript: new appLogin.filterMe();
  • gs.include('appLogin'); filterMe();           OR         javascript:gs.include('appLogin'); filterMe();
    • org.mozilla.javascript.EcmaError: "filterMe" is not defined.     Caused by error in Phase 2 Jelly: file:/glide/nodes//4_16033/webapps/glide/itil/WEB-INF/ui.jtemplates/doctype/template_bar.xml.2 at line 1==>     1: gs.include('appLogin'); filterMe();
  • applogin.filterMe();
    • org.mozilla.javascript.EcmaError: "applogin" is not defined.     Caused by error in <refname> at line 1==>     1: applogin.filterMe();
  • javascript:applogin.filterMe();
    • org.mozilla.javascript.EcmaError: "applogin" is not defined.     Caused by error in Phase 2 Jelly: file:/glide/nodes16033/webapps/glide/itil/WEB-INF/ui.jtemplates/doctype/template_bar.xml.2 at line 1==>     1: javascript:applogin.filterMe();
BUT
Anything happens on my filter,
What am i making for isn't work?
Can you just try without javascript in your dynamic filter's script field (in your screen shot you are using javascript keyword), like,
new appLogin().filterMe();
OR
gs.include('appLogin');new appLogin().filterMe();
16 REPLIES 16
Deepak Ingale1
HI Tiago,
Could you please share more info.
Screenshots or snippet of the code what you are trying to achieve will help to troubleshoot.
HI deepak.ingale,
Now, I'm sharing my screenshots on my first post.
Anurag Tripathi
Giga Patron
Hi Tiago,
Is it in the format:
new <includename>().<function name>();
you did not mention () after the script include name
-Anurag
HI t_anurag ,
I'm trying after your post, but still not working.
Thant You
