Flow designer issue
12-05-2023 02:57 AM - edited 12-05-2023 02:59 AM
Hello All,
We have encountered a problem with the flow designer where we are unable to open any flows, including out-of-the-box flows. Whenever we attempt to open a flow, we receive an error message stating, 'Your flow cannot be found. Flow sys_id:Name is required for creating a Flow'. The same issue occurs for subflows and actions as well.
This issue arose after cloning and upgrading to the Vancouver (patch2-hotfix1a) version.
Also, scripts are missing in workflows.
Note: This issue is only occurring on the test instance and is not present in DEV and PROD instances.
We try to resolve this issue by cloning from PROD to Test again.
Thank you,
03-31-2025 01:27 AM
Hello @Sonu Parab , Is your issue resolved? How you have resolved? I am also facing same issue for same instance only.
