Flow designer - Restarting a flow
Ni3
Just wondering if anyone has a script that can restart a flow and not trigger approvals.
We have a flow that queries AD through the mids and this sometimes fails for whatever reason. Essentially we just want to give the flow a restart. I know this was possible in the old workflows. Anyone have anything for flow designer?
Rupali1
Hello Ni,
 Please find below link might be it will help you to solve the issue.Please mark helpful it it will really helps you.
https://youtu.be/EPOsxq4O1dE
Thanks & Regards,
Rupali Bondar,
9082121282
Ankur Bawiskar
not possible to re-run the flow in flow designer
You can delete the context record via background script or from sys_flow_context table.
Also, you can execute the startFlow() API to create a new context of the flow once the executing/errored out flow context is deleted.
Refer below doc for Flow API:
FlowAPI
Sample script for running flow from script
try {
		var inputs = {};
		inputs['current'] = ; // GlideRecord of table:
		inputs['table_name'] = 'incident';
              // Execute Synchronously: Run in foreground.
              // var timeout = ; //timeout in ms
              //sn_fd.FlowAPI.executeFlow('global.test_flow', inputs, timeout)
              sn_fd.FlowAPI.executeFlow('global.test_flow', inputs);
	} catch (ex) {
		var message = ex.getMessage();
		gs.error(message);
