Flow designer script
User_267
In flow designer based on few options, short description should be updated .
Ex: code field -single line text
Catalog item name.
Choice-4 options(1,2,3,4)
Short description should be in this format-
Codefeild value-catalog item name-choice(based on user selection)
How to write script for this in flow designer.
If user selects 1 in choice field then - code field -catalog item name-1
Same with 2,3,4
How to write this in flow designer script
Dr Atul G- LNG
Hi @User_267
You can do via concatenate and by passing the variable in Flow.
https://www.servicenow.com/community/now-platform-forum/how-to-populate-task-short-description-based...
Mark Manders
Mega Patron
You can just set your 'short description' field to the selected data pills, combined with text. You can just write the text and add the data pills to the text box.
Mark
