How to retrigger flow for RITM
KartikM49574975
Hello All
I have approximately 100 Requested Items (RITMs), and I've made modifications to an existing Flow. Is there a way to retrigger the existing Flow for those 100 records?
Any assistance in resolving the issue would be greatly appreciated.
Thanks and Regards
Kartik Magadum
Sumanth16
Mega Patron
HI @KartikM49574975 ,
(function() {
var grScReqItem = new GlideRecord('sc_req_item');
grScReqItem.addEncodedQuery("Query");// provide a Query
grScReqItem.orderBy('sys_created_on');
grScReqItem.setLimit(1);
grScReqItem.query();
while (grScReqItem.next()) {
try {
	var flow = grScReqItem.cat_item.flow_designer_flow;
	var flowName = flow.sys_scope.scope + "." + flow.internal_name;
    var inputs = {};
    inputs['request_item'] = grScReqItem; // GlideRecord of table: sc_req_item
    inputs['table_name'] = 'sc_req_item';
    var contextId = sn_fd.FlowAPI.startFlow(flowName, inputs);
  } catch (ex) {
    var message = ex.getMessage();
    gs.error(message);
If I could help you with your Query then, please hit the Thumb Icon and mark it as Correct !!
Thanks & Regards,
Sumanth Meda
Thanks for your response.
Could you please provide step by step guidance.
Amit Gujarathi
I trust you are doing great.
Pease find the code for the same:
// Replace 'your_flow_api_name' with the actual API name of your Flow
var flowApiName = 'your_flow_api_name';
// Replace 'your_query' with a query that matches the 100 RITMs you want to target
var ritmQuery = 'your_query';
var ritmGR = new GlideRecord('sc_req_item');
ritmGR.addEncodedQuery(ritmQuery);
ritmGR.query();
while (ritmGR.next()) {
    // Trigger the Flow for each RITM
    sn_fd.FlowAPI.startFlow(flowApiName, null, null, { 'record': ritmGR });
Could you please provide step by step guidance..
