How the Comments or Worknotes are updated in Portal and Native Ui ?
Ramu6
Actually i want to know how the Comments are updated in Portal and native Ui once we post?, where these coming from
Please help me to understand this
Ramu
The reason for me posting the article is that the use of record watcher in the widget. The widget in the Service Portal "watches" the comments/work notes field and when it is updated it refreshed the HTML and makes it visible in the Service Portal. There is no server side functionality that are required in order for this to happen.
The activity stream is a macro in native UI, and you can have a look at the code. I do not know that macro in detail.
Anil Lande
There is Ticket Conversation <"widget-ticket-conversation"> widget embedded in the form/ticket widgets.
You can check Service Portal widgets and look at the logic how these entries are fetched and updated.
Please appreciate the efforts of community contributors by marking appropriate response as correct answer and helpful, this may help other community users to follow correct solution in future.
Anil Lande
Ramu6
@Anil Lande
yes, this is the widget which was handling that part, but it is only for portal , it not handling the Native Ui side actually
Ramu
PankajK67712898
Hi Ramu,
Activities tab records the change of your record in journal form and i think it is the default behaviour of activities field to dnyamically show the change of values in the portal/native ui without refreshing the page.
You can also update worknotes from script and it will appear in the form/ portal as usual. The script is as below-
var gr= new GlideRecord('sc_cat_item');
gr.get(current.item);
ritm.work_notes=gr.description;
ritm.update();
Please mark my answer as helpful and the solution accepted if it serves the purpose.
Pankaj Kumar
