How to add Choice values
surajsironi
Please suggest me how to add choice values from array.
Array CHOICEVALUES[value,label]
[chat,Chat,voice_call,Voice Call,walk-in,Walk In,email_fire,Email Fire]
Issue : Now How to add choices from Workspace client script using with for-loop
function onClick(g_form) {
    var fields = [{
        type: 'choice',
        label: getMessage('invoice type'),
        value: getMessage(' -- Select -- '),
        choices: [{
            displayValue: '',
            value: ''
        mandatory: true
        type: 'string',
        label: getMessage('Invoicer'),
        value: g_form.getDisplayValue('consumer'),
        readonly: true,
    g_modal.showFields({
        title: "Product for Invoice",
        fields: fields,
    }).then(function(fieldValues) {
        g_form.setValue('short_description', fieldValues.updatedFields[1].value);
        var ga = new GlideAjax('CDAInvoiceProcessor');
        ga.addParam('sysparm_name', 'getInvoiceTypes');
        ga.getXML(populateChoiceeField);
        function populateChoiceeField(response) {
            var msg = response.responseXML.documentElement.getAttribute('answer').toString();
            if (msg != '') {
                msg = msg.split(',');
                if (msg.length > 0) {
                    g_form.clearOptions(fieldValues.updatedFields[0].name);
                    g_form.addOption(fieldValues.updatedFields[0].name, '', '-- None --');
                    for (var i = 0; i < msg.length; i = i + 2) {
						fieldValues.updatedFields[0].value= msg[i];
						fieldValues.updatedFields[0].displayValue= msg[i+1];
if you wish to add None then do this
Script Include:
var arr = [];
// to add None
arr.push({
	"value":"",
	"displayValue":"-- None --"
var DWN = new GlideRecord("u_customer");
DWN.addQuery("u_active", true);
DWN.addQuery("u_name", "Customer Specific Type");
DWN.addQuery('u_customer',' b70c0f830f37330013a831ef68767e33');
DWN.query();
if (DWN.next()) {
	PARMS = DWN.u_parms.split(',');
	gs.info("PARMS " + PARMS.length + "--" + PARMS);
	for (var i = 0; i < PARMS.length; i++) {
		var obj = {};
		var choice = new GlideRecord('sys_choice');
		choice.addQuery('name', 'incident');
		choice.addQuery('language', 'en');
		choice.addQuery('element', 'contact_type');
		choice.addQuery('inactive', false);
		choice.addQuery('value', PARMS[i]);
		choice.query();
		if (choice.next()) {
			obj["value"] = choice.value.toString();
			obj["displayValue"] = choice.label.toString();
			arr.push(obj);
var result = {};
result["choices"] = arr;
return JSON.stringify(result);
Workspace client script:
	var fields = [];
	fields.push({
		type: 'string',
		readonly: true,
	ga.getXMLAnswer(populateChoiceeField);
		var msg = response;
		var answer = JSON.parse(msg);
		fields.push({
			type: 'choice',
			choices: answer.choices,
			mandatory: true
			fields: fields,
20 REPLIES 20
i have applied your script in Onchange client script first to check what values it returning , It is Returning "Null"  , but not sure what was the error.
declared obj{}, result{} in in global , updated script-include like this.
obj.value = choice.name.toString();
obj.displayValue = choice.label.toString();
arr.push(obj);
gs.info("choice values in array" + arr);
but same value repairing in choice field {"choices":[{"value":"u_crd","displayValue":"CRD"},{"value":"u_crd","displayValue":"CRD"}]}
it might be issue?
fields.push({
type: 'choice',
value: (answer.choices && answer.choices.length > 0) ? answer.choices[0].value : '',
mandatory: true
Okay populating the choice dynamically is working
now thing to check why it's repeating.
declare the obj within the for loop
var arr = [];
DWN.query();
if (DWN.next()) {
        var obj = {};
        choice.query();
            arr.push(obj);
var result = {};
try to remove that json key
just keep this and check
fields.push({
type: 'choice',
mandatory: true
after adding obj{} inside For-look now two values getting populated
fields.push({
type: 'choice',
mandatory: true
I request you kindly update your client script and script-include with your latest changes in thread , i will mark it.
Can't we show "-- None --" ? and user must select value
