How to Auto close incidents in 5 working days, after incident state is resolved.
Balaram7
Hi all,
Please help me with this below requirement.
We are using incidents properties OOB to move incidents to closed state after 5 days once the incident state is set to resolved. This will run in weekends as well. can we restrict this to run only for 5 working days in a week.
If yes please help me with the right way to achieve this.
Thank you,
Balaram.
@Balaram
Create schedule job which runs daily and use below script
It would check if the days between created and now time is more than 5 working days i.e. the difference is excluding weekends
updateRecords();
function updateRecords(){
try{
inc.addQuery('state', 6);
inc.query();
while(inc.next()){
var start = new GlideDateTime(inc.sys_created_on);
var nowTime = new GlideDateTime();
var days = getDateDiffExcWeekends(start,nowTime);
// if days more than 5
if(days >=5){
inc.state = 7;
inc.incident_state = 7;
inc.active = false;
inc.update();
catch(ex){
gs.info(ex);
function getDateDiffExcWeekends(start , end){
        var days = 0;
        while (start < end) {
            start.addDaysUTC(1);
            if (start.getDayOfWeekUTC() != 6 && start.getDayOfWeekUTC() != 7){
                days++ ;
        return days;
12 REPLIES 12
@Balaram
Hope you are doing good.
Would you mind closing the thread by marking appropriate response as correct so that it benefits future readers.
How to test it in incident table I'm not sure after changing the code in schedule script please let me know
Prasant Kumar 1
Please follow below screenshot:-
Property field:- Number of days(integer) after which resolved incidents  are automatically closed.
If I am able to solve your query, Please mark my answer  correct and helpful.
Thanks & Regards
Prasant Kumar Sahu
