How to auto populate catalog item variables?
User177031
I want to auto populate the Manager, Location and Department based on 'Requested_For' under Variable Set. Also want to auto populate the same when logged in user try to change the 'Requested_For'.
I tried writing "OnChange" Client script but facing an error on Portal page as "There is a JavaScript error in your browser Console". Attached the screenshot.
Also tried as per below URL but still the issue exists.
https://community.servicenow.com/community?id=community_question&sys_id=196b8b21db9cdbc01dcaf3231f96193b
Can anyone please help me with the Script?
Vishal Khandve
Hi Sai,
try below one-
var gr = g_form.getReference('requested_for',callBack);
function callBack(gr){
g_form.setValue('manger',gr.manager);
g_form.setValue('phone_number',gr.mobile_number);
g_form.setValue('email',gr.email);
g_form.setValue('location',gr.location);
g_form.setValue('zipcode',gr.zip);
g_form.setValue('country',gr.country);
g_form.setValue('company_code',gr.company);
Thank you
vinothkumar
You have to modify as below
var abc = g_form.getReference('Requested_for', setUserInfo);
function setUserInfo(abc) {
if (abc){
g_form.setValue('Manager', abc.manager);
g_form.setValue('Location', abc.location);
g_form.setValue('Division', abc.department);
Hi Vinoth,
I tried the code as per your suggestion, but it is not populating the values.
- Sai.
Vishal Khandve
Hi Sai,
try below one-
Thank you
Naveen63
Hi Sai,
Please try below script for auto populate catalog item:
SC Client Script - function onLoad() {
var Recipient = g_form.getValue('variables.recipient');
var geRecipient = new GlideAjax('autopopulate');
geRecipient.addParam('sysparm_name', 'recipientInformation');
geRecipient.addParam('sysparm_user_sysId', Recipient);
geRecipient.getXML(autoPopulateFields);
function autoPopulateFields(response) {
var arrRecipientInfo = answer.split('!#!');
if(arrRecipientInfo[0] != '') {
g_form.setValue('variables.yourmanagervariablename', arrRecipientInfo[0]);
if(arrRecipientInfo[1] != '') {
g_form.setValue('variables.yourlocationvariablename', arrRecipientInfo[1]);
if(arrRecipientInfo[2] != '') {
g_form.setValue('variables.yourdepartmentvariablename', arrRecipientInfo[2]);
Script include:
Script Include - var autopopulate = Class.create();
autopopulate.prototype = Object.extendsObject(AbstractAjaxProcessor, {
recipientInformation: function() {
var userInfo = "User not found";
var user_sys_id = this.getParameter('sysparm_user_sysId');
var grUser = new GlideRecord('sys_user');
if(grUser.get(user_sys_id)) {
userInfo = grUser.manger;
userInfo+= '!#!'+grUser.location;
userInfo += '!#!'+grUser.department.getDisplayValue();
return userInfo;
Mark this answer as Correct and Helpful if helps.
Naveen
