12-22-2020 03:30 AM
i tried to below ways
- : javascript:scriptincludename().functionname();
- javascript: new scriptincludename().functionname();
- javascript: new functionname(); script include name is same name as function name
javascript: functionname(); script include name is same name as function name
could anyone help on this
02-02-2021 04:55 AM
Solution is script include and function name should be same and be called javascript: functionname();
12-22-2020 04:51 AM
i am trying to create module , where trying to filter incident based of user location through script include
12-22-2020 05:07 AM
I am not sure about arguments, but I usually create these kind of modules as below.
1. Open actual table list view.
2. Set filter condition using JavaScript as required.
for ex: assignment group.sys_id - is one of - javascript:getMyGroups();
run the filter.
if filter working as expected, copy the URL post ".com/" and paste it in module link and set module type as URL.
12-23-2020 02:33 AM
if you are returning comma separated sys_ids of location from script include, you can set argument as below.
Similar to above you can try.
But one question, why you are going with argument when you can put script include in condition builder or even create module of type URL and copy direct URL?
12-23-2020 02:03 AM
12-23-2020 03:19 AM
Hello Manish,
If you are using link type as list of reocrds then arguments is basicaly used to filter those records.
If that is the case, then you can call like this
javascript:
sys_id=javascript:new scriptincludename().functionname();
OR
sys_idINjavascript:new scriptincludename().functionname(); (If your SI is returning an array of sys_ids)
For more information, go to sys_app_module.LIST in your instance and filter by
Arguments contains New()
and
link type is list of records and check the available arguments.
Mark the comment as a correct answer and also helpful if this helps to solve the problem.
