How to delete records between a start and end date using sys_auto_flush?
TEJAS
Hi everyone,
I’m leveraging the sys_auto_flush table to automate record deletions in a scoped application. For most scenarios, I calculate the age field based on standard timeframes (like "last X days"), and everything works as expected.
However, I’m trying to support a use case where users define a custom date range with a start and end date.
To implement this, I currently calculate age as the difference (in seconds) between the current time and the end date, with the assumption that sys_auto_flush will delete records older than that end date.
This works in deleting records older than the end date, but what I really need is to delete records only between the start and end dates — not beyond.
Question:
Is it possible to configure sys_auto_flush to target only records within a specific date range (start to end).
Appreciate any best practices or suggestions others have used for similar requirements!
Thanks in advance
Aditya Kumar6
In the particular scenario it will be easier to use the data management service:
Category Data Management Jobs sys_auto_flush Table
TypeConfigurable scheduled jobSystem-level buffering mechanism
User AccessAdmin-configured via UIMostly hidden, platform-managed
Example Tablessys_cleanup, sys_archive_schedulesys_auto_flush, affects sys_journal_field
GoalManage system data retention and storageImprove performance of journal field updates
Common UseDelete logs, archive incidentsCache and flush comments, work notes
You can also look into scheduling them refer : https://www.servicenow.com/community/developer-articles/how-scheduling-data-management-delete-jobs-w...
Please mark this answer helpful if it answers your query
