how to disable a view ? ex: mobile view from my instance
dhruva
Even though i have used hidden option or assigned admin role to mobile view, still itil users are able to see mobile view in the task tables or any other table. please advice an alternative approach.
Hi Dhruva,
Thank you for the screenshot. What you are showing in the image is a list view. Be sure to delete the appropriate tables from both the Forms Sections and Lists related lists (both shown in the above image.) If you have it available in the list, select that view, then open a record, it will display like your image in the form header as well even though there may not be a mobile view for that form available.
Okay. Thanks for the response and all the help.
Laukik.
