How to drill down on a reffence field
John H1
Senario:
We have two department fields (Department & Sub-Department)
Department is the Parent of Sub-department.
The goal is to select Department and have the ability to select the sub-departments based on the the Parent field being the parent value
Hi @John H1 ,
You can use the below reference qualifier:
javascript:u_parent=current.u_department;
You can change the field names based on your table structure.
I'm not getting the results I was expecting.
I have a Department field called IT
I have a second Department call Server Team (Parent = IT)
What I'm trying to do is have a reference field and then select the IT department
then in another reference field only have it show the Departments that have IT as a Parent (in this case Server team)
Please follow the below steps:
1. Goto the Dictionary entry of "Server Team" field
2. In "Use reference qualifier" field select "Advanced"
3. In the "Reference qual" field put the below code:
// Assumimg the name of the "IT" field is "it" and parent field of the "Server Team" table is "parent"
javascript:parent=current.it;
4. Goto the Dependent field section and in the "Dependent" field put the name of the IT field (Assuming "it")
5. Save the form.
