How to get mandatory approvals from two people in a workflow and until the two of them approve, it should be 'Requested' and once both of them approve then only it should be 'No longer required'.
utkarsha_s
Kilo Expert
Hi Guys,
Let me know how to get mandatory approvals from two people in a workflow and until the two of them approve, it should be 'Requested' and once both of them approve then only it should be 'No longer required'. If the first person has approved, still it should be in Requested state until one more person approves and then no longer required.
How do I achieve this from a workflow ?
Utkarsha Saxena
Try following code in approval activity of your workflow.
Raj
26 REPLIES 26
Can you try with Approval User activity
I tried the same on my dev instance and it worked.
Can you please share the screenshot of the apporval activity where you are setting these conditions?
Raj
Hi Raj,
Please find the image screenshots I have put.
There are 2 methods.
1) You need to use Approval User activity (if there is only a single group is involved).   My script will work in this method. You are currently using Approval Group.
2) You need to use Approval Group activity (if there are multiple groups are involved). In this case try following script
var id=0;
for (var id in groups) {
var group = groups[id];
if ( group.approved ==2)
answer='approved';
Plz set the for loop depending on number of groups involved.
Raj
Hi Raj,
Yes I made that script on approval user activity and it worked. Thanks a lot. Now this works for me as well ! Appreciate all the help and patience !
Utkarsha
