03-29-2020 12:03 AM
03-29-2020 12:09 AM
Hi Henry,
unfortunately you could not since gs.getProperty('name') only works in server side
Also performing GlideRecord in client side is not recommended
Are you referring to use that in onload client script of some table; if yes then you can use display business rule on that table; get the property value and store in scratchpad variable and use that variable in onload client script
BR:
g_scratchpad.propertyValue = gs.getProperty('property_name');
Client Script:
function onLoad(){
var propertyValue = g_scratchpad.propertyValue;
If you are referring to using it in catalog then perform GlideAjax and use script include to get the value and return it from function
03-26-2022 11:45 PM
Hi
Could you please provide sample script include for this, How to call system property in script include.
Prasad.
03-29-2020 12:33 AM
Hi Comp,
1.Create a script include.Use gs.getProperty in that script include.
2.Call the previously created script include from client script.
Please mark correct or helpful if this solve your issue.
Swapnil
03-29-2020 01:23 AM
Hi there,
Ankur as 100% correct when it concerns Platform UI. Go for a Business Rule which sets the scratchpad. Going for a Script Include only makes sense when working on the Service Portal.
Just wanted to add:
For the Platform UI, you might find this utility helpful, creates a Related Link with which you can easily see which scratchpads are available (out-of-the-box and what you added) and what the contents is:
"Show Contents of g_scratchpad" Tool
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
04-05-2020 09:44 AM
Hi Henry,
Any update on this?
Can you mark my answer as ✅ correct, 👍 helpful if you were able to achieve the requirement. This enables other members to learn from this thread.
