How to get the variable values in flow designer
Sriram Pusuluri
Hi Team,
I have a flow designer, Once I submit the item, Ritm and sc_tasks are creating.
Now in sc_task short description I want to add one of the variable value in it.
I have added above one in my flow designer Action, this is coming in below way
Below is how my variable values are showing in catalog form
How to do this? Do I need to create any other Action
@Sriram Pusuluri
1 thing to check -> if that variable is select box then why it shows Search Icon
try this other way in script
Also check if there is any space in the variable name
var choiceLabel = fd_data.trigger.request_item.variables.addon_licence_project.getDisplayValue();
return choiceLabel;
20 REPLIES 20
@Ankur Bawiskar  type is select box
Ankur Bawiskar
@Sriram Pusuluri
I believe you must be having flow on your catalog item
Simply in that you can get the variable value using "Get Catalog Variables" flow action
What type of variable is that?
@Ankur Bawiskar
this is select box type variable.
It is populating value in short description, but I need Text to display
@Sriram Pusuluri
if you use "Get Catalog Variables" flow action on choice variable it gives you the Text
if you are fetching the choice value using data pill, it will fetch the choice value and not label.
I shared solution for thing recently
How to display the choice text instead of its value in subject of request through Flow Designer.
Solution
1) create a flow variable of type String
2) then use "Set Flow Variable" flow logic and use the script to fetch display value/choice label and set
3) then use this flow variable in your catalog task description from data pill
@Ankur Bawiskar  I have created flow varaible type as string.
where can I set 2 nd point.
