how to hide some variables from multi row variable set?
mounika32
how to hide few variables from multi row variable set? I have used ui poilcy its hiding from the form when user clicks on ADD but its not adding from the table
how to hide from the table as well?
AniketC85155510
Hello @mounika32 ,
Based on my understanding, currently, there isn't a direct method to hide variables from the Multi-Row Variable Set  table view after hiding them within the form. Unfortunately, this seems to be a limitation in the current functionality.
In my experience, whenever I've hidden variables within the MRVS, I've encountered the challenge of not being able to hide them from the table view of MRVS.
Please Mark ✅Correct if this solves your query and also mark 👍Helpful if you find my response worthy based on the impact.
Aniket
mariuskrug93
You can hide fields in list with css.
Take your developer tool from your browser.
For TH:
And for TD:
Now right-click and ctrl on the widget and then click instance in page editor:
Add CSS here:
th[id="id-question-a6974cb91b64d210b362997bbb4bcb19"]
  display: none;
td[headers="id-question-a6974cb91b64d210b362997bbb4bcb19"]
  display: none;
This works great on the item form but the column still appears on the RITM. I wish there was an easy way to hide in both...Thanks!
deepak81519
You can create an onLoad catalog client script to hide the columns. Please note it only works on the portal not on RITM. Make sure, Isolate Script is false as we're accessing DOM objects
function onLoad() {
    var COLUMN_TEXTS = ['Column1', 'Column2', 'Column3']; // add column names here
    // Wait until the MRVS table renders (it loads asynchronously in Portal)
    var attempts = 0;
    var maxAttempts = 40; // ~10s with 250ms interval
    var poll = setInterval(function() {
        attempts++;
        var allHidden = hideColumns(COLUMN_TEXTS);
        if (allHidden || attempts >= maxAttempts) {
            clearInterval(poll);
            if (allHidden) {
                attachObserver(COLUMN_TEXTS);
    }, 250);
    function hideColumns(columnTexts) {
        var headers = this.document.querySelectorAll('th');
        if (!headers || headers.length === 0) return false;
        var hiddenCount = 0;
        for (var c = 0; c < columnTexts.length; c++) {
            var columnText = columnTexts[c];
            var targetHeader = null;
            for (var i = 0; i < headers.length; i++) {
                if (headers[i].textContent.trim() === columnText) {
                    targetHeader = headers[i];
                    break;
            if (!targetHeader) continue;
            targetHeader.style.display = 'none';
            var headerId = targetHeader.id;
            if (headerId) {
                var cells = this.document.querySelectorAll('td[headers="' + headerId + '"]');
                for (var j = 0; j < cells.length; j++) {
                    cells[j].style.display = 'none';
            hiddenCount++;
        return hiddenCount === columnTexts.length;
    function attachObserver(columnTexts) {
        try {
            var table = this.document.querySelector('table');
            if (!table || typeof MutationObserver === 'undefined') return;
            var observer = new MutationObserver(function() {
                hideColumns(columnTexts);
            observer.observe(table, {
                childList: true,
                subtree: true
        } catch (e) {
            /* ignore */ }
