How to Move the problem state from 'Fix in Progress' to Resolved based on condition?
Ashok32
Hi ,
I have a requirement
when Problem Record moves from state "Fix in progress" to "Resolved" it needs to check the condition ie..,When the Problem task is Open then the Problem record will not move from "fix in progress" to "Resolved" and display error message .If problem Task is closed then the problem record will moves to Resolved state.
Thanks in advance
Harish KM
Hi you can have a before update Business rule on Problem Table
Condition: when state changesto resolved
Script:
var pTask= new GlideRecord("problem_task");
pTask.addQuery("problem",current.getValue("sys_id"));
pTask.addQuery('state','NOT IN','2'); //  Problem Task state not in closed
pTask.query();
while(pTask.hasNext()){
gs.addErrorMessage("If problem Task is closed then the problem record will moves to Resolved state "+current.number);
current.setAbortAction(true);
Hi harish
I tried the above code.But it checks all the problem records states,and it takes toooooo long to display that error message.
