How to populate a Reference field automatically (no dot-walking, GlideAjax)
Alberto Consonn
Hi guys,
I need an help for configuring the Advanced Reference Qualifier in the right way.
In the Time Worker table, I've created a Reference custom field "Account_ref" to the customer_account table.
I would like to fill this field automatically with the account of the selected task, I tried dding with the following Advanced Reference Qualifier...no luck.
javascript:'account='+current.task;
Thanks for your help!!!
Dubz
Hi Alberto,
I replicated your config and figured out the issue, real rookie error for which i accept full responsibility 🙂
The function call in the getXMLAnswer() line is in quotes, it shouldn't be! use this:
//client script
	var ga = new GlideAjax('TestScriptInclude');
	ga.addParam('sysparm_name', 'testFunction');
	ga.addParam('sysparm_task', g_form.getValue('task'));
	ga.getXMLAnswer(getAjaxData);
	function getAjaxData(response){
		g_form.setValue('u_account_ref', response);
EDIT: Just noticed Harsh has already picked this up!
36 REPLIES 36
Something happened but the value is still not correct...weird
can you please confirm the client script and script include has been written in global scope ?
also please share the screenshot of your client script and script include.
also in your client script replace the getXML() to getXMLAnswer().
validate again and see are you getting the same error.
I've replaced getXMLAnswer() as you proposed, but nothing happened, no value in the field Account_ref...weird!
Below the printscreen of the client script and the script include.
Please help.
Hi Alberto,
If you use getXMLAnswer() you don't have to use var answer = response.responseXML etc etc line (it does that for you which is why i always use it over getXML()).
if you just write below for your getAjaxData function what does the alert show?
alert('this is the response: ' + response);
cheers
Dave
Alberto Consonn
In this case, the response is correct, so why it's not updating the value? I can't find the problem..
