How to populate a Reference field automatically (no dot-walking, GlideAjax)
Alberto Consonn
Hi guys,
I need an help for configuring the Advanced Reference Qualifier in the right way.
In the Time Worker table, I've created a Reference custom field "Account_ref" to the customer_account table.
I would like to fill this field automatically with the account of the selected task, I tried dding with the following Advanced Reference Qualifier...no luck.
javascript:'account='+current.task;
Thanks for your help!!!
Dubz
Hi Alberto,
I replicated your config and figured out the issue, real rookie error for which i accept full responsibility 🙂
The function call in the getXMLAnswer() line is in quotes, it shouldn't be! use this:
//client script
	var ga = new GlideAjax('TestScriptInclude');
	ga.addParam('sysparm_name', 'testFunction');
	ga.addParam('sysparm_task', g_form.getValue('task'));
	ga.getXMLAnswer(getAjaxData);
	function getAjaxData(response){
		g_form.setValue('u_account_ref', response);
EDIT: Just noticed Harsh has already picked this up!
36 REPLIES 36
I've found it, so using getXMLAnswer() I must remove the variable answer definition, in this way it works fine.
function getAjaxData(response) {
Thank you very much for your help, I really appreciated it!!!
Cheers
Alberto
Glad you got it working 🙂
Alberto Consonn
Last thing still not clear for me: do you know how to do the same with an onSubmit() client script instead of onChange()?
What do we need to change in these code?
Thanks a lot
Cheers
Alberto
in an onSubmit script you'll need to use getXMLWait(), this runs the call synchronously so it waits for the response, otherwise the call is asynchronous and your form will submit before the data is returned to the client.
Generally best to avoid synchronous ajax calls if you can, validation can be done onChange or with a before insert/update BR. With this requirement, i don't know why you'd do this onSubmit, tbh i would have put this in a before insert BR.
Alberto Consonn
Make sense, at first I was thinking to populate the value only when someone change the Task, but make more sense to do a Before BR, as you said...how will be the BR? I'm wondering the code is different in this case, could you give me an example please?
Alberto
