06-10-2019 10:52 PM
I have a used one ui macro in a catalogue item. For one reference field i have used <g:ui_reference tag, how to put reference qualifer in <g tag?
Sirraj
06-24-2019 12:11 AM
I have solved this issue by referring below thread,
https://community.servicenow.com/community?id=community_question&sys_id=78da0b6ddb5cdbc01dcaf3231f961998
- Sirraj
06-11-2019 02:22 AM
Hi Ankur,
No this table i only have created. Its a UI macro only, where i have created a table creation dynamically.
For var2, since its a reference field refering to another table i have used <g:ui_reference tag. Everything working as expected. Only need to apply reference qualifier or query condition to display only selected records on var 2.
-Sirraj
06-11-2019 02:44 AM
Hi Sirraj,
Ok I believe that won't work.
as I said in my previous comment you cannot set values from client side <script> tag to g:evaluate or g:ui_reference
06-11-2019 02:54 AM
Thank you for the response and your valuable input Ankur.
I'll check once again and will inform my mgr the same.
Thanks again , will mark your answer correct after one round of search. Have a nice day.
Sirraj
06-11-2019 02:28 AM
I also referred the below link as well, but dont know how to set my query in var2.
https://community.servicenow.com/community?id=community_question&sys_id=b4d8cb61db5cdbc01dcaf3231f9619eb
06-24-2019 12:11 AM
- Sirraj
