How to re-trigger Flow/Approvals on RITM without manual state change or new flow?
RitheshB
Hi everyone,
I’m working on a scenario in ServiceNow where a Flow is handling approvals and updating a Requested Item (RITM).
Current situation:
  • The Flow triggered approval activities correctly.
  • One of the approvers did not approve, so the request moved to Cancelled state.
  • The record updates (stage, approval, etc.) were executed as expected.
Now, I want to re-test the same Flow logic by bringing the RITM back to a previous “Approved/In Progress” state and re-triggering the process.
However, I want to avoid:
  • Manually changing the state and fields
  • Creating a separate Flow just for testing
  • Cloning/recreating the RITM
  • Manually changing the Request state and testing the flow
My question:
 Is there any recommended approach to:
  • Reset/replay the Flow execution on the same RITM?
  • Re-trigger approvals and downstream tasks without creating new records or flows?
  • Possibly use Flow Designer execution context, rollback, or any system-level mechanism?
I also checked Flow Context, but looking for a more controlled or reusable way to simulate/restart the process.
Any suggestions or best practices would be really helpful.
Thanks in advance!
J Siva
Hi @RitheshB
I’m not sure if you’ve tried the Test option in the flow.
Try testing the flow by passing the RITM number and clicking Test.
This will re-trigger the flow.
Siva
