How to set the Custom list view for reference field?
Ajay37
I have gone through several community threads and blogs, but I didn't find answer. I have a reference field on Table which is referring to "sys_user_grmember" table. By default it is showing the "sys_id" when I lookup through reference field, but I want to show the custom list view with only "user" column in the list. Is it possible to configure list for only this field.
I have tried using "sys_ref_list", but it effects globally. I also tried by configuring sys_popup view, but it is only effecting at the form level when we click on the info icon beside field.
Ajay
Ankur Bawiskar
Hi Ajay,
I don't think you can set it only for this field
When you click the lookup it would show the sys_ref_list
That would be a global change.
Also marking User field as display=true would be a global change.
But if you are not using this table as Reference table in any of your existing tables you should be fine with making the dictionary change for User column as Display=true
Hi Ankur,
Thank you. Why I am trying to do this is, I want to show the users of particular group in that reference field, so I referred to "group member" table and have given condition as group is xyz. I also tried an alternative, by creating two fields A and B, A is referring to group table and have set up the default value of required group in that field and made B dependent on A, it worked successfully. But it result in creation of extra field, so in order to eradicate that, I am trying this way.
Got it.
You can make the User field as Display=True if you wish to since this table is not much used as reference.
Let me know if I have answered your question.
If so, please mark appropriate response as correct & helpful so that this thread can be closed and others can be benefited by this.
Thank you. Will do that.
You are welcome
Ayushi Gaur
Hey @Ajay37 , currious to know that did you find a way to change 'sys_ref_list' for a particular field only.
