How to track incidents created on different portals.
01-03-2018 04:07 AM
Hello friends.
I have two different portals and i need to track the incidents created in each one.
The problem is: When an incident is created on any portal the 'Contact type' of the incident is 'Self-Service' and this way i don't know what portal created the Incident.
Thanks in advance!
Incident Management
02-23-2018 01:08 PM
I would create a custom identifier that is attached to each record producer. if record producer "x" is used then the incident has a custom field populated with "x",
Create a custom field on the incident table called "Record Identifier"
In the record producer script I would use the follwing
//Set record Identifier
current.record_identifier = "A";
If your user fills out an incident from portal B you would have the script on record producer B as follows.
current.record_identifier ="B";
C...
Current.record_identifier ="C";
And then you can report off of the record_identifier column.
02-23-2018 02:03 PM
That will be beneficial for going forward, thank you! I should have been more specific. I need it for historical reporting for example, incidents created in the month of January.
02-23-2018 02:43 PM
I would not overwrite the record producer field with a special value. I'd leave that as the record producer so you can say how many from "guest incident" I would write the portal to the correlation id or correlation display field . These fields are used to store additional details like external inc # or other needed info.
so now you can say group by record producer and group by correlation display. so now you can see how many time x form was used per portal
Another option is to add to the contact type choice list and keep the self-Service but add Self-Service - Portal A / Self Service - Portal B
