I want to copy the cause notes, problem fix notes and workaround from problem RCA task to Problem
Balakrishna_ABK
"Cause notes" from RCA Task should be copied to  "cause notes" in Problem record
"Workaround" from RCA Task should be copied to  "workaround" in Problem record
"Problem fix notes" from RCA Task should be copied to "fix notes" in Problem record
all above should be done when problem task is closed
	var problem = new GlideRecord('problem');
	problem.get(current.problem);
	problem.cause_notes = current.cause_notes;
	problem.workaround = current.workaround;
	problem.fix_notes = current.fix_notes;
	problem.update();
})(current, previous);
Aoife
Use an After or Async Busines Rule on the RCA Task table.  I'm not positive on the following field names, but the idea should work.
current.parent.cause_notes = current.cause_notes;
current.parent.workaround = current.workaround;
Aoife
Hi Aoife, can you send me the complete script for the same ?
	problem.update();
Thanks Aoife, its working.
