is it possible to add ref_contributions on variable attributes
srikanthvk
Giga Expert
I have been trying to use a macro on service catalog, I do not want to add it as a UI Macro variable type but want to show it beside a variable like in form fields.
Please help me if any of you tried it earlier. Thanks in Advance.
srikanthvk
Giga Expert
we have achieved this using one of the scripts provided in servicenowguru.com, below is the link
Refer section add_me UI macro for catalog variables
http://www.servicenowguru.com/system-ui/ui-macros/add-me-ui-macro-user-group-fields/
11 REPLIES 11
ref_contributions and field_decorations will not work in variable attributes.
sumeet_n
Mega Guru
Also may be you can try field_decorations. I have not used it, but wiki says it is similar to ref_contributions.
srikanthvk
Giga Expert
Weird. But you had asked for a solution with no UI macro .. Glad though you came up with a solution
it actually isnt a UI Macro, we get the control of element where we need to show the icon and add anchor tags to it.
