Is it possible to create permissions that prevent someone from referencing a field
ayano
Giga Guru
Is it possible to create permissions that prevent someone from referencing a field in the Incident table?
For example, is it possible to set it so that a certain user cannot see the Description field of an Incident?
2 ACCEPTED SOLUTIONS
armanoj
Hi @ayano ,
Please make a clarity on the given requirement ,
1. ACL - Controls data access at the server level,Prevents unauthorized users from reading, writing, or creating field data and Security – always use if you want to truly restrict data access.
2. UI Policy - UI Policy to Hide the Field Visually.
This involves using Field-level ACLs for security, and optionally, UI Policies or Client Scripts to improve the user experience.
Arun
Hi @ayano ,
2 ACLs would be required. one is for table level and one is for description field
please share your business requirement in detail we will help you with ACL configuration part
Chaitanya
armanoj
Hi @ayano ,
Arun
