Is it possible to provide iframe in spModal?
09-14-2022 12:59 AM
In portal, I had a sentence.. when I clicked on it..a popUp needs to open ... in that I want to show some website.. ex: w3 schools website... so what should I need to write?
HTML
<div>
<p ng-click="c.clck()">Click here to open Popup</p>
</div>
Client controller
api.controller=function(spModal) {
/* widget controller */
var c = this;
c.clck= function () {
spModal.alert('How do you feel today?').then(function (answer) { // In this line what should I write?
09-14-2022 01:46 AM
which form is this? catalog or normal form?
09-14-2022 02:21 AM
Hi Ankur,
It's a widget..
03-05-2026 05:32 AM
Hi @Sathwik1
You get a blank screen because the website uses the X-Frame-Options security header to prevent its content from being loaded within an iframe, a practice often implemented to mitigate general security risks.
Refer to this stackoverflow link for more information:
https://stackoverflow.com/questions/7289139/why-are-iframes-considered-dangerous-and-a-security-risk
