Message "Comment cannot be viewed by Technicians until work begins on the Requested Item"
dlively
Giga Expert
Getting this message on INC0080649, but there is nothing on the "Related Records" tab.  Where is this message coming from and how can I eliminate it?
Thank you,
Donna Lively
you can just comment that line of code by adding '//' before that line. see below code.
function queueAssigneeEvent() {
var assigneeArr = [];
var assignGroupArr = [];
//Query for non-pending sc_task records
var catTsk = new GlideRecord('sc_task');
catTsk.addQuery('request_item', current.sys_id);
catTsk.addQuery('state', '!=', -5);
catTsk.query();
if (!catTsk.hasNext()) {
//gs.addInfoMessage(gs.getMessage('Comment cannot be viewed by technicians until work begins on the Requested Item'));
And this Business Rule is on your Incident record??
The Business Rule performs a query on the Catalog Task table, where request_item exactly has the sys_id of your current record, and where state of the Catalog Task is not -5. If no rsults: this message is generated.
This doesn't look like a out-of-the-box business rule. You could ask around why this has been setup. If not needed: simply deactivate this Business Rule.
Kind regards,
Mark
LinkedIn
Community article list
hirotosakai
Hello, this message exists here.
/sys_ui_message_list.do?sysparm_query=key%3DComment%20cannot%20be%20viewed%20by%20technicians%20until%20work%20begins%20on%20the%20Requested%20Item
Business Rules:
/sys_script_list.do?sysparm_query=scriptLIKEComment%20cannot%20be%20viewed%20by%20technicians%20until%20work%20begins%20on%20the%20Requested%20Item
