My Approvals not working for Delegates
Prati
As per OOB functionality my approvals should show list of requests which are needs to be approves this should work for approve as well as his delegate. but it is not working for delegates. i checked with filter which as approver is javascript:getMyApprovals(). this is fine also i tried by activating Business rule approval query.
Can anyone help on this??
Thanks and Regards,
Pratima Deshmane
Hi Prati,
did you check the delegate record has valid values; start and end date is proper
approvals checkbox is true
What happens if you open the record directly using sysapproval_approver.LIST
13 REPLIES 13
approval check box was true but valid values were expired.. thanks for your help:-)
what changes i have to do if i want to do same for portal??
Hi Prati,
not sure on the portal side. Is it not showing up for the delegate user the approvals on portal?
No it is not showing on portal, actually i checked with my approval pending widget as well but it is just showing message as no approval pending.
hey i am able to reflect it on portal as well.. just made some code chnages in widget server script
