My Approvals not working for Delegates
Prati
As per OOB functionality my approvals should show list of requests which are needs to be approves this should work for approve as well as his delegate. but it is not working for delegates. i checked with filter which as approver is javascript:getMyApprovals(). this is fine also i tried by activating Business rule approval query.
Can anyone help on this??
Thanks and Regards,
Pratima Deshmane
Hi Prati,
did you check the delegate record has valid values; start and end date is proper
approvals checkbox is true
What happens if you open the record directly using sysapproval_approver.LIST
13 REPLIES 13
Hi Prati,
Can you share what update you made to make it work? It would be helpful
Yes sure Ankur..
i have modified script to this:-
var u = getMyApprovals();
var gr = new GlideRecord('sysapproval_approver');
gr.addQuery("approver", u);
gr.addQuery("state", "requested");
gr.orderByDesc('sys_updated_on');
gr.setLimit(50);
its working for me and now delegate users are able to see list of request which needs to be approved by approver or his delegate.
Raghesh
Giga Expert
We have similar issue. Approver user 'A' delegated to 'B', now when 'B' logs into Service Portal and unable to see the Approval tab itself. Is there any role required for user 'B' to view the approval requests which are delegated to him.
regards,
Raghesh
i have the same issue, has anybody an solution (Iam on Paris Release)
