need help on incident assignments
Saurabh Anand
Hi Community,
I have been asked a question about the assignments of incidents to the assignment group members. Say we have an assignment group that has 50 members and we receive 200 incidents daily. What should we do to assign equal number of incidents to each members.
Please help me on this.
Saurabh
3 ACCEPTED SOLUTIONS
yes you go to configure it, its pretty simple to configure it after installation.
you can explore the doc which @AndersBGS  has shared. this will help you configure it step by step.
if it helped kindly mark the answer helpful / correct to move it to answered queue...
☑️ Please mark responses as HELPFUL or ACCEPT SOLUTION to assist future users in finding the right solution....
LinkedIn - Lets Connect
Hi @Saurabh Anand ,
Advanced work assignment needs to be configured - you can read more about it here: https://docs.servicenow.com/bundle/vancouver-servicenow-platform/page/administer/advanced-work-assig...
Best regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
Dr Atul G- LNG
Hi @Saurabh Anand
Experts already answered AWA is the best option but it will not work alone. you need to do configuration like
Skill, availability as well and then it will work.
Sohail Khilji
@Saurabh Anand ,
No worries , servicenow has a module called 'Advance work assignment' which takes care of ticket assignment automatically based on your team size, efforts and capacity. You can install and configure that plugin to use it for this use case.
i hope i helped you...
AndersBGS
Hi @Saurabh Anand ,
You should explore: https://docs.servicenow.com/bundle/vancouver-servicenow-platform/page/administer/advanced-work-assig...
This will in general assign incidents based on availability, capacity and skill.
Best regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
Thanks for your response @AndersBGS and @Sohail Khilji, I can see this plugin is free and I am installing it currently but after installation do we need to configure this plugin based on tables or will it automatically work for all the tables.
