Need to Disable comment filed for Incident ,enhancement and Defect forms.
venkatesh76
I got the requirement that I want to disable comment(additional comment) for incidents, enhancements and Defects once they are moved to closed completed state. Please provide your suggestions, Thanks!
Ankur Bawiskar
@venkatesh76
you can hide them using field level READ & WRITE ACLs and add condition as Active=false or state=closed
what did you start with and where are you stuck?
@venkatesh76
Hope you are doing good.
Sandeep Rajput
@venkatesh76 You can create a field level write ACL on the comment field on the incident, enhancements and Defects table to make the comments field read only.
