Notification Approval
Poorva Bhawsar
Hi Community,
I have a new state specific to a catalog item. I want to hide this new state, it should only be visible to a catalog item. Once this state is selected, it should trigger an approval to a group. If approved, need to change the state of the server ci from inbuilt to active. All SC tasks attachments needs to attach on the ci selected on the form.
I have this client script to hide this new state.
function onLoad() {
    var item = g_form.getValue('cat_item');
    if (item != 'a60987578739a514aa3574497bbb3533') {
        g_form.removeOption('state', 5);
But its hiding this state option for all catalogs. I want to show this for a specific catalog item.
12 REPLIES 12
Poorva Bhawsar
I got the solution created ui policies and added scripts in advanced option to add or remove these.
Hi
Where is your actual reply? I only see your very lengthy signature? Or is this your new way of chasing people for marking your answer as correct?
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
