‎02-10-2026 06:07 AM
Hello Community,
I would like to change the format of the Mobile phone (mobile_phone) field in the User [sys_user] table.
Currently, the phone numbers are displayed in the following format:
Example: 1(449) 260-6439
However, I would like the numbers to be displayed and stored in a simple numeric format like:
Example: 06212348725
Requirement:
I want the Mobile phone number to:
Be displayed exactly as entered
Not automatically formatted with country code, parentheses, or dashes
Use a plain numeric format (example: 06212348725)
Althout i have disable the sys properties for us format but u still have the probleme :
Sys_properties : glide.ui.format_phone
Thank you for help
‎02-11-2026 12:37 AM
Resolution
For the old "Phone Number" data type
The phone number format for this field is controlled by a client script. By default, it only supports phone numbers in local format for some western countries.
Follow these steps to customize this script to show the phone number in the local format of your own country.
For example, users in Japan enter "334561234" in the field and hope it will be converted to "(03) 3456-1234" in Japan local format automatically.
Steps:
- Navigate to the sys_ui_script.list table
- Create a new UI script record with this information:
- API Name = formatting.js (Or any preferred name)
- UI Type = Desktop
- Active = true
- Open this client script copy it into the newly created record:
Script :
‎02-10-2026 06:27 AM
Hi @ahmed-24
what is the use case change data type of the Phone Number field. It is not recommended because this field is used in On-Call, FSM, and CSM as well. If it is changed to a string, users would be able to enter anything, which would not be the correct behavior.
‎02-10-2026 06:56 AM
hello @Dr Atul - LNG
‎02-10-2026 08:45 AM
Hi @ahmed-24
What is the use case for converting this data type to a string? What are you trying to achieve by changing it?
Please consider that this field is not just a phone number field—it is used for on-call purposes, CSM, FSM, and other integrations where messages are sent to phone numbers. Changing the data type would disrupt all of these functionalities.
This data type is by design and serves a specific purpose, so it should not be changed. If you need additional flexibility, it would be better to create a new field and, through logic, convert it to a string and use it instead, rather than modifying the existing platform field.
‎02-10-2026 08:33 AM - edited ‎02-10-2026 08:44 AM
HI @ahmed-24 ,
setting the system property (glide.ui.format_phone) to false is working for me
if you still facing the issue try clearing the cache or try to use a different browser or try incognito mode
if you are still facing the issue
try this
create a client script on sys_user table
function onLoad() {
if (g_form.hasField('mobile_phone')) {
var mp = g_form.getValue('mobile_phone')
if (mp) {
g_form.setValue('mobile_phone', mp.replace(/[^0-9]/g, ""));
var mobilePhone = g_form.getControl('mobile_phone');
mobilePhone.setAttribute('onChange', '');
if (g_form.hasField('phone')) {
var phone = g_form.getValue('phone')
if (phone) {
g_form.setValue('phone', phone.replace(/[^0-9]/g, ""));
var phoneElement = g_form.getControl('phone');
phoneElement.setAttribute('onChange', '');
also you would have to run a fix script or Background script to fix the existing data
var userGR = new GlideRecord("sys_user");
userGR.addEncodedQuery("mobile_phoneISNOTEMPTY^NQphoneISNOTEMPTY");
// userGR.setLimit(10);
userGR.query();
while (userGR.next()) {
var mp = userGR.getValue('mobile_phone')
if (mp)
userGR.setValue('mobile_phone', mp.replace(/[^0-9]/g, ""))
var phone = userGR.getValue('phone');
if (phone)
userGR.setValue('phone', phone.replace(/[^0-9]/g, ""))
userGR.update()
}result
Please mark my answer as helpful/correct if it resolves your query.
Chaitanya
Resolution
Steps:
- UI Type = Desktop
- Active = true
Script :
