populate short description in RITM based on field on catalog form and should update short description in that particular RITM only
how to populate short description in RITM based on field on catalog form and should update short  description in that particular RITM only
why not use workflow?
you must be having workflow linked to that catalog item right?
if you are using BR then you can use condition as this
current.cat_item.name == 'Your Catalog Item Name'
