Problem description max_length
hpesata
Kilo Expert
Hi!
I am currently working on getting data out of the problem table.
I am getting the schema out of the sys_dictionary definitions for the "problem" and the parent "task" table.
The "description" field of the "task" table has a max_length of 4000.
This is the value that I take for the destination storage, unfortunately I am encountering a problem record,
where the description field holds a 9547 character string, which of course doesn't fit into my destination,
because of the max_length attribute being 4000.
how is this possible, that the description field can exceed the max_length value of 4000 and how can I determine
the real maximum length of a field during the schema query?
Thanx in advance!
regards,
Hans
Good morning!
I found a description on how large text fields are handled here:
http://www.servicenowguru.com/scripting/client-scripts-scripting/maximum-length-large-string-fields-...
Thanx and regards,
Hans
Andre Moreira
Kilo Expert
Hi Hans,
Here some tips on the Wiki:
Ref.: Variable Types
Ref.: System Dictionary
[]'s
Andre Moreira
Hi Andre!
Thanx for Your reply!
I was reading through the Wiki articles but couldn't find any hint on how it can happen, that the description field can hold more characters than the specified 4000.
I found another problem record which has a description with more than 62000 characters !
maybe using an aggregate query on the description length would be an solution to find the real maximum value ?
Thanx and regards,
Hans
We have a couple of text fields set to length = 1,000,000 (for transferring large blobs of JSON data around).
Good morning!
Thanx and regards,
Hans
