‎01-30-2020 07:11 AM
I have a variable on a catalogue item that references the locations table. I want that variable to only list locations whose parent = the signed in user's location. EXCEPT if the signed in User's location = MG. If the signed in user's location is MG then I want the variable to list all locations on the table.
function advloc() {
var locPar;
var userLoc='';
var gr=new GlideRecord('sys_user');
gr.addQuery('sys_id',gs.getUserID());
while(gr.next()){
userLoc=gr.location;
if(userLoc.includes("MG")){
locPar = "";
else {
locPar = "parent = userLoc";
return locPar
I think it is not working because it returns the name of the location and not the Sys_Id, but I'm not 100%.
Service Catalog
‎01-30-2020 07:39 AM
You're on the right track. That script belongs in a script include that is client callable:
And in your reference qualifier you would just do:
new getLocation().locations();
‎01-30-2020 08:41 AM
Can you share screenshots of what you've setup now?
From the advanced reference qualifier + script include?
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
‎01-30-2020 08:45 AM
‎01-30-2020 08:49 AM
I'll have a look.
Can you in the meantime add between lines 20 and 21:
gs.info('DEBUG: ' + gr.location.getDisplayValue() + ' / ' + locaPar);
When you then reload your form, what is written to the logs?
Kind regards,
Mark
‎01-30-2020 08:56 AM
Invalid query detected, please check logs for details [Unknown field null in table cmn_location]
Invalid query detected, please check logs for details [Unknown field function advloc() {
var locPar;
var userLoc in table cmn_location]
‎01-30-2020 09:02 AM
Hmm strange. That's not in your screenshots. advloc is also your old function name? Can you find out if it's still used anywhere?
The scripting itself, tested here, works.
Kind regards,
Mark
