Regular Expression help
Michael M1
Giga Expert
I need to extract the user name from an AD attribute.
The string looks something like "CN=Rosana Smith,OU=Employees,..."
I wrote an expression of: var mike = str.match(/\b(\w)+ (\w)+/jg);
This works, except if I run into a name of Rosana Smith-Jones, it will not capture the third name. If I adjust to match against this then it doesn't work for non-hyphen names. Also, some people have 3 names "Billy Rae Cyrus".
My question is, how can I write an expression to capture all characters between (but not including) the CN= and the first comma (,) ?
Here is how you would get the name out of the string:
var myString = "CN=Rosana Smith,OU=Employees,..";
var myRegexp = /CN=(.*?),/g;
var match = myRegexp.exec(myString);
gs.print(match[1]);
The idea is you want to retrieve the first matching group and not the match itself.  Run it in a Background Script or in  Xplore: Developer Toolkit.
Jim Coyne
I believe this should do it:
/CN=(.*?),/g
Jim -
This is always what I thought as well - everything in the parenthesis is what gets extracted, but that is not what is happening.
If I put your suggestion into ServiceNow I get the following output:
Script: CN=Rosana Smith,
gs.print(match[1]);
var str = "CN=Rosana Smith,OU=Employees,...";
var
mySubString = str.substring( str.lastIndexOf("=") + 1, str.lastIndexOf(",") );
Please mark the answer helpful or correct based on the impact of the response.
Reference: https://stackoverflow.com/questions/14867835/get-substring-between-two-characters-using-javascript
Ishan Parikh
