relationship and m2m tables
ginia dey1
Giga Contributor
hi all,
I wanted to know the difference between m2m table and relationship table since i am getting confused because both can be used to make related lists then what is the difference?
Thank you
Ujjawal Vishnoi
Hi Ginia,
Relationships:
Adding a Reference field on table A that points to table B, creates a relationship that ServiceNow can understand. This allows you to add a related list on records in table B, that displays the records from table A that are linked to it.
M2M table:Creating a M2M table via the sys_m2m relationship definition table also creates a relationship that ServiceNow can understand. Because of this, you can add a related list on either of the two tables linked by the relationship, to show related records from the other table.
Regrds
Ujjawal
