Remove Gap between Fields.
Hemanth Naik
Hello everyone, I have a requirement
I have a field "category" when form loads initially its value is "none" .so I am trying this scenario when category value changes to other ". I want to hide Description and short description fields. I have written a client script to hide them and remove the gap between the fields but as the fields are in different sections the gap is not clearing. Can any one please help How to remove gap between them.
code:
    if (isLoading ) {
    if (newValue == 'Other') {
        g_form.setDisplay('description', false);
        g_form.setDisplay('short_description', false);
    else{
        g_form.setDisplay('description', true);
        g_form.setDisplay('short_description', true);
Hi @Hemanth Naik
UI policy i mentioned to avoid client script. There is no way to overcome this space, as we are hiding attribute not removing so it will be still there.
@Anubhav24 , Thanks for replying
As, i checked it worked only when fields are in same section, if you checked with condition of other section fields can you please add screenshots, As you said i checked those fields they don't have any conflicting scripts.
