Reporting on Survey Results
sreekeerthi
I want to create reports for survey results and show a specific report range particular to HR Cases. I tried using asmt_metric_result table but I could not create report range as OOB ranges are already defined in ServiceNow. So i created the report on "asmt_assessment_instance_question" table and added report ranges.
Can we use "asmt_assessment_instance_question" for reporting survey results. Do we have any challenges if we use this.
Thank you in advance!
Sree Keerthi Kasula
J Siva
Hi @sreekeerthi
Yes, you can use Assessment Instance Question table to report on survey results.
We are using the same and it's working fine.
Siva
@Shivani_singh Will chcek and let you know
Hi @J Siva
Any idea how to do it?.
sreekeerthi
Thank you for confirming!
