Request item table not visible in flow designer
Akhil Vinay Ma1
I'm unable to see "sc_req_item" table in flow designer.
If it's on your personal dev, you go to developer.servicenow.com and login. Then through manage instance->actions->activate plugin. There in the list you should have something like "flow for service catalog" or similar.
//Göran
15 REPLIES 15
That is what I thought.. In Kingston there wasn't any connection to Service Catalog etc. It's was just a async flow you could connect. In London you now can connect it to catalog items. and to not have potential issues, you can no longer trigger it directly by selecting it as a table.
//Göran
So how can we Trigger Service Catalogs ?
I London you can attach a flow to a catalog item instead of a workflow. You might need to activate the plugin for it, but then it's possible yes.
//Göran
Plugin name ?
//Göran
